Driver door ajar message
MKVIIILSC
Forest Grove, Oregon
This message often comes up on the message screen. But not always. (door definitely closed)
Is there a way to adjust it?
'97 Mark viii LSC
Mine did this constantly and the odd ball fix is spray the door latching in the door as best you can with a spay lube while working the door. It actually fixed the issue.
Clean the rubber seal along the bottom of the door really well. If there's crap on the seal you'll get the message. This is how I fixed the problem on mine.
