Drive Belt Help
  • Thread starter Thread starter HighRule
  • Start date Start date
H
HighRule
Guest
I was filling/bleeding my coolant. While filling it at the bottle it stated coming out at the fill cap all over the belt. I poured a bunch of water on it to rinse it off.
Currently I'm letting it dry. Will this be an issue? It does say not to contaminate the drive belt with coolant. I have not tried starting my LS until it's dry.
You may develop some slip / squeal initially, but if it's washed off well it should be fine. I've done the same.
My belt was covered in coolant last night, don't worry you'll be fine !
I just rinsed it off a little (without getting the engine wet) and bara bing bara boom :cool:
Dried and started. I now have heat and AC for the first time since buying the LS.
Feels Good! :cool:
Just check it a little extra at the next oil change, make sure it hasn't dried out and cracked.
