Door Sensor
LINCBRA
KS
Does anybody know where the door sensor (driver side) is on a 1998 Lincoln Mark 8? The reason i am asking is because sometimes when i shut my door it says driver door ajar? It is pissing me off because i just bought the car in october.
Been discussed much before. Very common problem. Spray wd-40 in the door latch and it should clear it right up. I also sprayed some silicon lubricant in there afterwards to keep it lubed up.
i used the WD-40 and it worked instantly
GMAN said:
I don't think you are going to be satisfied. On Gen 2's WD40 may work, but it didn't work for me. I went ahead and replaced the $13.00 part. Check out my link I started back in October.
http://www.lincolnvscadillac.com/showthread.php?t=27253
It took three days for the WD to work for me. I had to play with the latch ALOT. I had a bad case, but it did work.
#13.00?! I would have just replaced it. Nice info!
