Door handle
fcb77
Cleveland
Greetings,
I need to replace the driver side door handle on my 95'. Has anyone ever tackled this before?
im pretty sure everyone has, check ebay, or even try max at five-star ford he will help you out. good luck!
fcb77 said:
Greetings,
check rockauto.com also. they may have a handle for cheap. There is an article in this forum on how to replace it. Do a search.
jdlmkviii said:
I have the same problem... I'm just gonna order one off of Max and have a body shop paint and put it on.
I went to the dealer got one for $40 and then I went and got it painted for $30. I did the r&r door handle.
i have replaced both of them within the last 6 months-the pass. side was my dads fault-i told him the damn door was locked.. he is full blood ITALIAN---HE DOESNT LISTEN!!!!!! THEY ARE RELATIVELY PRICED THEY ARE PRETTY EASY TO PUT IN IF YOU ARE NOT CAR RETARDED TAKE YOUR TIME YOULL NEED IT TRUST ME IF A SHOP DOES IT MAKE SURE THEY US WHITE LITHIUM GREASE ON THE HINGE OF THE HANDLE ITSELF IT WILL START TO STICK WHEN YOU OPEN IT IF THEY DONT USE THIS
MARK CORSO
