Dome Lights
Goddard-MarkVIII
Portland
My dome lights still arent working along with any interior lights besides dash lights arent working went through all the fuses to check and see if they were burnt out. I looked in the owner manuel to see if i was missing a fuse but it doesnt look the same. Anyone have any ideas? a real reference that matchs.
Is there maybe some wire that gets messed up commonly?
did you check to see if there is power at the dome lights if not trace back until you get power should find the problem there
It doesn't matter which door you open? Maybe it's the door popper, not recognizing that the door's open.
The switch should turn them on though, I doubt you're overlooking to check that. heh ...... just a thought.
