DIY: Window Regulator Replacement VIDEO
Awesome post. Will be doing this exact procedure in a week or two.
Thanks M4rk!
why buy a new regulator?
if the motor still works, then most likely the plastic clips have broken, you can get them on ebay. just take off the old one and put on the new clip, so easy!
or if you want, get a soldering iron and plastic weld the old clip and broken piece back together with some reinforcement pieces, good as new.
check out plastic weld with soldering iron on youtube.
are gen1 - gen2 the same or different?
i have gen2; rear passenger side window goes up and stays up, but when you press the button for it to go down it slips/slides down. had an accident on side that totaled the car, heard something rattling around inside the door last time i shut it. havent felt like messing with it bc god knows i have bigger problems in life, but just wondering if yall think a clip is broken or if its just off the track or what? thanks
