scjmc
I need to change the oil in my differential (125K). I found in the FSM that it takes 1.4 liters, or 3 pints of synthetic 75w-140. I also read that you are supposed to fill it to 1/8 to 3/16 of an inch below the fill plug. My question is this where is the fill plug at? I looked at a parts diagram and cant locate the fill plug. I also need to know if the old fluid has to be pumped out or if there is a drain. I took a quick look under the car and didnt see a fill plug or drain. Thanks......
