I tried to do the DATC Module Self Test.....I tried every combo of defrost and off then auto to start it. Nothing. It will not run the self test. I reset it by pressing wiper heater and off then auto.
To start the self test on the DATC.
while in Off mode.
press, OFF and FLOOR buttons simultaneously.
immediately press, AUTO after releasing the OFF & FLOOR.
It should begin a series of test from 25 down.
when finished it will show DTC errors for any present faults,
if no faults, it will lite up the entire display, allowing you to see all possible displays.
Any other button to exit, which hard boots it and finishes it by leaving it OFF.
AUTO to rerun and it will be back to 75F default settings, blower motor will run on high for a few minutes.
Every time you exit from the self test mode it clears any DTC's and recalibrates to defaults.
If you can't even get the DATC to go into the self test or you are not able to properly control anything, it's most likely already done for.
There are all sorts of pin-out tests for different faults but most just pick up a used DATC from a scrapper and try from there.
