dccv was replaced when it shorted out-got the service ((P)) indictor. a/c worked for a while and would quit.
then would work off and on blowing hot air when not working. let this go for some time and finally started to check it out myself.
when i bled the system myself it had air in it, took awhile but got full stream out the heater bleed valve. all was fine for about a month but now hot air again.
i can not get the system to bleed again, just a trickle but what would cause this after it was bled once.
