not insults intended, but i have done plenty of tuning myself. and it doesnt throw and CEL's unless the o2 itself is bad.
So, what you're saying is that removing the rear O2 sensors from the exhaust stream will not cause a CEL? Computer only throws a CEL if the sensor is bad?
Tell me, how... exactly does the computer know the sensor is bad? Could it be something with the ECU seeing voltage values that are out of range for what it knows it should be seeing and it's not seeing said values? Like, for example, leaving the sensor out of the exhaust stream? No, it couldn't be something as simple as that, right?
The sensor doesn't have self testing capabilities. It doesn't send the ECU a memo when it dies in order to tell the ECU to light up that little CEL.
yes i do agree that its not the proper way to do it but it is a cheap way to take care of that issue until you have the money to go in with a laptop.
Go in with a laptop? Why not just go buy a tune that addresses the issue? "Go in with a laptop..." Do you even know what you're talking about?
technically messing with the emissions monitors within the computer on a emissions controlled vehicle is illegal and not for street use.
And your point, being?
not saying that i dont do it but as a tx state inspector if i wanted to be a real douche bag (and im not) if i saw that it had been messed with i can fail the vehicle for it.
So, how exactly do you fail someone who leaves the sensors in place and turns them off with a tune, again? How, when every other state emissions stations merely check for OBDII Emissions readiness codes and or other non emission related codes? This varies from state to state, but as an emissions inspector, you know that Emission readiness codes are first and foremost the sniffer is looking for.
What, you take your "laptop" in to work with you and analyze someone's ECU parameters? Please.... don't insult my intelligence... tiny as it may be.
i never claimed that what i said was proper just an alternative.
A very poorly executed alternative.
i prefer to go in with a laptop and just remove them.
So, since you're such an uber tuner with your "laptop", tell me something:
What software parameters do you need to change in order to do this? Hint, there are 4 to 7 parameters you need changed to accomplish this task, based on the year, catch code and model.
