cylinder numbers
9_8_L_S_C
Plainfield
Ok did a search came up empty-need to know which cylinders are what number for 98 lsc-so looking at front of car what are the numbers-I havve a misfire in 6 so i need to know were to start thanks
wo thanks for the quick reply :) now just have to see who has the best price for cops-advanced auto is$42 each
note, BEFORE you go out and pull the coil, i would recommend getting a replacement boot, especially if this is your only vehicle!! if your valve covers are leaking into the plug hole the boot will turn to mush and fall apart as you remove the coil
yeah 2 of them fell apart-so i need the valve cover gasket and the donut gaskets correct?-are these dealer only parts?
not sure........but good chance.
did the #6 boot fall apart? i would get all new boots while your at it, and if you replace some that are ok then you have spairs. mine are leaking a little bit too but ive just delt with it (i have 7 spair boots in my tool box)
all fixed-its funy how many places dont stock these cops-i got them at pep boys :eek: thanks moe and chicken for the heads up
save youe old coil, usually its just the boot that goes bad causing the miss, and you can get those throught ford for around 10 bux never hurts to have a spair
