Cruise control button removal ?
Trippen Out
Pinellas Park, Florida
Anyone know how to pop the tops off the buttons for the cruise control on the steering wheel. It almost feels like you could just pry it but I dont want to force it if there is a trick. also same question in regards to the window and lock buttons in the door. is there anyway to get them to pop off so there is access to the bulb under them ?
Are your lites not working? Mine aren't either. Not sure how they might work?
The window button switch covers are a pain! you have to be careful popping them off because the posts that hold them in place, break off very easily. I just glued mIne back on. Good luck, and let us know what the outcome is.
The window button itself doesn't come off really..or at least its not mewnt to be removable, the whole switch cover that surrounds the button is just clipped in, there's a clip toward the rear of the car and the front of the switch cover has two hooks that go under the door panel..so pop the back off and slide it back and it comes out.
