The CrossFire 350 and 305 were never marketed as a performance" engine, by any means.  When people raised the hood on the Corvette, seeing something that looked similar to a later 60s cross-ram intake (as some Chrysler HEMI race engines used), they automatically presumed "max performance".  In reality, that system was more of a transitional toward the later EFI engines, more than anything else.  With the capabilities of the engine to be able to run at sub-2000rpm levels in OD on the highway with improved emissions and such.
No performance< per se?   The lower half of the intake, which had the ports in it, had ports that were about 75% as tall as a normal 4bbl intake.  A big ledge at the bottom!  I suspect this was a band-aid fix for the fact that a bit too much unvaporized fuel would be in the ports, so the ledge was there to induce some turbulance to get the larger droplets back into the air flow and more vaporized as a result.  At the lower rpms, that added turbulance helped the mixture, but didn't affect part-throttle power and response.
When we got the first ones in, I took off the air cleaner to look at it running.  Large fuel droplets were in evidence.  Such that I laughed and said "Throw a match in there and cook weinies".  Obviously, the spray pattern was not what it should have been, but "good enough".   No doubt, the later TBI units, especially the 2bbl versions, had much better spray patterns and atomization characteristics such that they were "bulletproof" in reliability and performance.
Enjoy!
CBODY67
