crazy climate control
topher5150
Grand Rapids, Michigan
So I'm cruising down the highway today with the heater on (floor position) then I switch to pnl/flr and it makes this crazy humming noise from the engine and the car starts to shake a little switch it back to flr its fine. Could this be some crazy vacuum thing I'm totally lost on this one
Sounds funny, but it was my alternator that was going bad whenever my climate control went crazy... replaced the alt when it died... no problems.
the eng bogging a little when ac is engaged is normal, the compressor puts another load on the eng when engaged
My heater control would especially flip out if I tromped on the gas from a roll... if it was off, it would turn on, light up every single light, blow a little air, then shut off.
