Cracked drilled and slotted rotors. Anybody out there experience this on an LS?
Lucky_Ls
Round Rock
I was talking with a friend this weekend about the brakes that I want to get on my LS. I brought up the website for R1 Concepts and the Premium Brake Rotors that I’m probably going to purchase. He goes; oh you want drilled rotors hu? From there he went on to say that because the rotors are not “cast” with the holes they will eventually crack. I told him that I’ve never heard of anybody with an LS having cracked rotors. He just kept on about the draw backs of drilled over cast. He also asked why I want these kinda brakes if I just use my car for daily driving and crusin on the weekends. I didn’t have an answer for him…
Anyway back to the question, anybody out there run into this problem with any brand of drilled and slotted rotors with regular driving conditions (daily driver, crusin, trips)?
the only issue that drilled and slotted rotors gives you is that they cant be turned if they get wapped, the brakes will last less cuz of the slots and you do hear a noise when you break thats cuz of the slots too, other than that they are fine, i have them put on and i did get mines from r1concept and they are good, but my next pair will be crossed drilled not slotted, think about it this way the high performace cars have crossed drilled rotors but no one has them sloted, so if the slots where that good the 100k plus sports cars will have them. and they dont, so just get them crossed drilled.
More facts about rotors. May the great myth of drilling rotors for improved cooling finally die...
here's some quotes from many known brake engineers and brake manufacturers in regards to slotting vs. drilled vs. normal.
Darrick Dong; Director of Motorsports at Performance Friction: "Anyone that
tells you that drilling makes the disc run cooler is smoking crack."
Power Slot: "At one time the conventional wisdom in racing circles was to cross-drill brake rotors to aid cooling and eliminate the gas emitted by brake pads. However, today's elite teams in open wheel, Indy and Trans Am racing are moving away from crack prone, cross-drilled brake rotors in favor of rotors modified with a fatigue resistant slotting process."
Stop Tech: "StopTech provides rotors slotted, drilled or plain. For most performance applications slotted is the preferred choice. Slotting helps wipe away debris from between the pad and rotor as well as increasing the "bite" characteristics of the pad. A drilled rotor provides the same type of benefit, but is more susceptible to cracking under severe usage. Many customers prefer the look of a drilled rotor and for street and occasional light duty track use they will work fine. For more severe applications, we recommend slotted rotors." (Note that even though Stop Tech sells both drilled and slotted rotors they do not recommend drilled rotors for severe applications.)
Wilwood: "Q: Why are some rotors drilled or slotted?
A: Rotors are drilled to reduce rotating weight, an issue near and dear to racers searching for ways to minimize unsprung weight. Drilling diminishes a rotor's durability and cooling capacity."
From Waren Gilliand: (Warren Gilliland is a well-known brake engineer in the racing industry and has more than 32 years experience in custom designing brake systems ...he became the main source for improving the brake systems on a variety of different race vehicles from midgets to Nascar Winston Cup cars.) "If you cross drill one of these vented rotors, you are creating a stress riser that will encourage the rotor to crack right through the hole. Many of the rotors available in the aftermarket are nothing more than inexpensive offshore manufactured stock replacement rotors, cross drilled to appeal to the performance market. They are not performance rotors and will have a corresponding high failure rate"
From Baer: "What are the benefits to Crossdrilling, Slotting, and Zinc-Washing my rotors? In years past, crossdrilling and/or Slotting the rotor for racing purposes was beneficial by providing a way to expel the gasses created when the bonding agents employed to manufacture the pads...However, with today's race pad technology, 'outgassing' is no longer much of a concern...Slotted surfaces are what Baer recommends for track only use. Slotted only rotors are offered as an option for any of Baer's offerings."
Grassroots Motorsports: "Crossdrilling your rotors might look neat, but what is it really doing for you? Well, unless your car is using brake pads from the '40s and 50s, not a whole lot. Rotors were first drilled because early brake pad materials gave off gasses when heated to racing temperatures, a process known as "gassing out." ...It was an effective solution, but today's friction materials do not exhibit the some gassing out phenomenon as the early pads. Contrary to popular belief, they don't lower temperatures. (In fact, by removing weight from the rotor, they can actually cause temperatures to increase a little.) These holes create stress risers that allow the rotor to crack sooner, and make a mess of brake pads--sort of like a cheese grater rubbing against them at every stop. Want more evidence? Look at NASCAR or F1. You would think that if drilling holes in the rotor was the hot ticket, these teams would be doing it...Slotting rotors, on the other hand, might be a consideration if your sanctioning body allows for it. Cutting thin slots across the face of the rotor can actually help to clean the face of the brake pads over time, helping to reduce the glazing often found during high-speed use which can lower the coefficient of friction. While there may still be a small concern over creating stress risers in the face of the rotor, if the slots are shallow and cut properly, the trade-off appears to be worth the risk. (Have you looked at a NASCAR rotor lately?)
AP Racing: "Grooves improve 'cleaning' of the pad surfaces and result in a more consistent brake performance. Grooved discs have a longer life than cross-drilled discs."
Well Done!!!:D
Drilled rotors are more susceptible to thermal cracking because they don't cool as well as a plain old run of the mill vented brake rotor.
WOW! Thank you for talking me out of getting drilled and slotted rotors! :D
I wont go back to OE standard rotors.
Maybe its the slotting, maybe its the drilling. Maybe its the non OE materials used. Whatever the reason, I am hard on brakes, and the cross drilled rotors on my F150, have lasted almost 3 times as long as the OE units.
I went with Slotted, and dimpled rotors from EBC, on the LS, and they are FAR superior to the OE units...I will never go back to an OE, or OE style rotor.
I had Stillen cross-drilled rotors on the front of my 87 LSC for a few years and never had a problem with cracking. Never wound up warping them either like the regular rotors that were on there previously.
I think you guys are missing the point; it's not that if you get drilled rotors they ARE GOING TO FAIL... it's only that they have the potential for a higher failure rate. Simple physical, metallurgy and thermal dynamics tell you drilling holes in a friction surface is counter-intuitive under most situations.
That's not to say an OE rotor may be of the worst quality while this cross drilled rotor you buy happens to be of far better quality; giving you the impression of the better quality and performance due to drilling. Chances are, if you took those same rotor blanks and used them... undrilled... you'd be even better off.
I run cryo treated powerslot rotors on my LS; only because the rotor quality is better; pad cleaning is a minor side benefit. The cryo treating has been proven to increase the life of rotors by up to 300%.
Oh, nice little added benefit with powerslot rotors... they can be resurfaced (unlike MOST drilled rotors). As I recall, the rule is that as long as the slot doesn't disappear, it's safe to have them turned. But don't quote me on the guideline!
I have a decision to make once it’s time to get brakes and rotors rather than just go right back to OE. There a part of me that’s wants to prove my friend wrong about the drilled slotted rotors buy getting them and showing him the quality of them but there so many choices on the market and to get one that has all the benefits of OE (noise, dust, life) I don’t know where to start? Thank you guys for all your post! Keep the feed back coming!!! :D
