Couple questons
darkhaven
Indianapolis
The ole girl is fast approaching the 1/4 mill mark and is getting a couple problems. Got some bad ball joints but I searched and found a couple threads on where we can just order the ball joint now and not the whole knuckle. The 1st real problem is my abs and trac con light are on I hooked up my scanner and it’s got a code for the abs pump anyone know a good way to diag the pump? Secondly the air cond is getting a bit confused in its old age it will be going down the road and both sides will be blowing nice and cold then randomly either the pass or driver side will start blowing out hot air and it will keep doing it until I shut off the car and restart it.
