Hey gang... it's been a while since I've been on here... Car's been pretty good to me with 120k on the clock.
Discovered my AC doesn't work anymore. Didn't think too much of it, figured some probably leaked out over time. Well after sending two bottles of 134a into it I found the problem. The high pressure line on the passenger side frame rail has a hole in it. It's the one that has the line sitting in that little crease on the frame rail with the heat tape stuff around it. Has anyone had to replace this aluminum line yet, and if so, how much of a PITA is it?
I'm starting to show other signs of wear, as I've replaced just about every suspension component in the car sans driver rear side. Now the rear is making noise.
I'm debating if it isn't time to retire her.
As always, thanks for the help!
