Cooling fan working but spinning slow
bwv2k
high point
Does anyone know where to get a repair manual that shows how to repair the hydraulic fan on my 01 ls. This car runs hot when I turn the ac on but not with normal driving and the ac off. I never hear the fan spin faster when the ac is turned on. Any sugesstions on what to look for?
cooling fan actuator
OK, here goes
You could have several possible problems, I am on my 4th fan and 3rd pump! There are three things possible on the mechanical side, 1 actuator, 2 pump, 3 fan motor. Any of them could go bad. It is a big PITA to repair it. It may be impossible without the skill, tools and knowledge to do it. Check for leaks, it is a simple system, actuator releases the fluid to turn the fan, pump provides compression. BUT I've read many a tale about not being about to remove the connecting system bolts. Me for one could never get them apart. Search for an electric replacement fan. There are plenty of ideas on this site. check out the other post on actuator replacement.
called dealership to price an actuator. runs around sevety buck. but they called it a blower speed com. Is this the same thing
you should do a search on for this in the forums. Lots of posts and different ideas. Will be worth your time to read through them.
