I recently had my coolant temp. sensor replaced and since I got it back from the shop, the fan is always on high speed, although the speed seems to be dependant on the RPM's of the vehicle.
I searched and some have suggested that it could be the fan pump actuator. Is this true? Any help is appreciated. Thanks.
Why was the CHT replaced?
The actuator normally fails such that the fan *never* speeds up, likely due to getting clogged.
The speed control for the hydraulic fan is pretty simple:
1) computer determines how fast it wants the fan (a/c on/off? CHT? speed? etc)
2) computer adjusts the PWM signal to the actuator
3) actuator modulates hydraulic line pressure
So if the pump and fan are working correctly (and having a fast spinning fan means they are), then it's either computer/sensors, cabling, or the actuator.
From looking at my old thread -
http://www.lincolnvscadillac.com/showthread.php?t=70387 - I think the actuator is normally open (full fan speed) and the PCM pulses it closed to regulate pressure.
So, either the actuator's solenoid coil has gone kaput, or it's not getting the signal.
First thing's first - is the actuator plugged in, and does it look like the cable isn't cut?
