conversion done. -- shock mounts??? ¿¿¿¿
stink 'N linc 'N
Windsor
I'm done puttingeverything in!! Hurray! Took me and a buddy about 7 hours. Taking the first solenoid of the passengers side was a lil bit of a sttruggle. After that, there was no problems after.. didnt have to take the endlink bolt off @ all. Drivers side went pretty quick, not really any problem with solenoid. When we were putting everything back on.. tighten the end link - steering knuckle assembly , bolt breaks. We call a couple places, finally find some instock. put the new part on, tighten it up (carefully) driverside done. Rears, were a breeZe. Put in the new shocks, had a lil bit of a tough time with the mounts. The bushings that were on the stock shocks i used them with new monroe sensa-trac. Should i have just got those bushings out by eg. burning them out. Then use the bushings that came with the shocks on that mount? The passengers side rear , now i can hear a knock/poppin sounds almost from the mount. The driverside side. is fine. I want to fix this lil problem?
I bought Eric Nesahm mounts. They worked perfectly and made things easy. I did the whole "burn em' out" thing, but wound-up with a problem and had to replace it anyways. $35 shipped 2-3 days, and you're good.
