Cold Air V6?
Voodoo
Reno
What up? This is my first of many posts I am sure. I have a problem. The cup of my air cleaner outlet pipe broke when I leaned on it (HUA). Just the portion between the air sensor and the manifold. I wanted to install a cold air intake and I cant for the life of me find a replacement for the section I broke. Is there an aftermarket one anybody would recommend? I cant find a kit that handles the entire assebly like the V8 applications.
Loosing my mind!
2000 LS
I'm assuming you have a Gen2 (03-05) v6. You are going to have to piece one together. Some of the guys here have put one together from the generic kits at Autozone or your favorite parts store. Others have had one custom made at a customs store. Basically, there are no aftermarket intake kits for the v6 like the v8 has. Even that one was made for the Thunderbird and not the LS.
welcome
What up? This is my first of many posts I am sure. I have a problem. The cup of my air cleaner outlet pipe broke when I leaned on it (HUA). Just the portion between the air sensor and the manifold. I wanted to install a cold air intake and I cant for the life of me find a replacement for the section I broke. Is there an aftermarket one anybody would recommend? I cant find a kit that handles the entire assembly like the V8 applications.
Loosing my mind!
2000 LS
There used to be one. I have it on my daughters '00. You might try contacting Ken at LSKoncepts and see if he has one laying around. He may even still have the plans available and can make one up for you.
Actually, Ken is probably your best bet.
Thanks fellas I had a feeling after two days of searching a bolt on wasn't going to be. How about a place to find a stock replacement? I can put a cold air box kit on the end of a stock tube yes?
I found some used stuff is that pretty much what I am looking at? Thanks guys you really are saving me a load of time.
