Coil conversion fronts only...
MatthewDavid
Denver
I was just curious I'm about to embark on the coil conversion journey and I was just wondering I got the whole kit but if time doesn't permit and we only get a chance to change the fronts... is there anything that's gonna be wrong with it?... has anyone else just changed the fronts?... the rear bags are fine... never had a problem... I just don't want to have to rush and have extra time just in case... one other thing I did hear you can do it but you have to adjust the sensor so the air ride error doesn't come up... any ideas/knowledge you can bestow on myself would be very kind :D
I am not sure about just doing the fronts. I can tell you this much though, If you can do the fronts then the rears should be no problem for you at all.
The front is simple to do, the rear is very simple. A friend helping should get you done fairly quick.
Do you have instructions for doing it?
Good luck.
