Codes
tacklebox
Fox Valley, WI
Where can I find help on engine codes? My check engine light came on so I stopped by autozone they pulled P.0. 412. The guy said something to do with air but had no idea what it was or how to fix it.
Secondary Air Injection (AIR) System Monitor Electric Air Pump System
The Secondary Air Injection (AIR) System Monitor is an on-board strategy designed to monitor the proper function of the secondary air system. The AIR Monitor for the Electric Air Pump system consists of two monitor circuits: an AIR circuit to diagnose problems with the primary circuit side of the Solid State Relay (SSR), and an AIR Monitor circuit to diagnose problems with the secondary circuit side of the Solid State Relay. A functional check is also performed that tests the ability of the AIR system to inject air into the exhaust. The functional check relies upon HO2S sensor feedback to determine the presence of air flow. The monitor is enabled during AIR system operation and only after certain base engine conditions are first satisfied. Input is required from the ECT, IAT, and CKP sensor, and the HO2S Monitor test must also have passed without a fault detection to enable the AIR Monitor. The AIR Monitor is also activated during on demand self-test.
The AIR circuit is normally held high through the SAIR Bypass solenoid and Solid State Relay when the output driver is off. Therefore a low AIR circuit indicates a driver is always on and a high circuit indicates an open in the PCM.
The DTC associated with this test is DTC P0412.
Diagnostic Trouble Code (DTC) P0412 indicates EAIR primary circuit malfunction.
Possible causes:
-- EAIR circuit open.
-- EAIR circuit short to power.
-- AIR bypass solenoid malfunction.
-- Solid State Relay malfunction.
-- Damaged PCM.
l Key off.
l Disconnect SSR.
l Key on, engine off.
l Measure voltage between B+ circuit at SSR vehicle harness connector and battery negative post.
l Is voltage greater than 10.5 volts?
Yes
Supplied voltage is OK, GO to «HM2».
No
GO to «HM6».
HM2 CHECK CONTINUITY OF EAIR CIRCUIT
l Key off.
l Solid State Relay disconnected.
l Disconnect AIR bypass solenoid.
l Remove Secondary Air dedicated fuse temporarily.
l Disconnect PCM. Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary.
l Install breakout box, leave PCM disconnected.
l Measure resistance between EAIR circuit at SSR vehicle harness connector and Test Pin 70 at the breakout box.
l Measure resistance between EAIR circuit at the AIR bypass vehicle harness connector and Test Pin 70 at the breakout box.
l Is resistance less than 5.0 ohms?
Yes
GO to «HM3».
No
SERVICE open EAIR circuit. REMOVE breakout box. RECONNECT all components. COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
HM3 CHECK EAIR CIRCUIT FOR SHORT TO POWER AND GROUND
l Key off.
l AIR bypass solenoid disconnected.
l PCM disconnected, breakout box installed.
l Measure resistance between Test Pins 70 and Test Pin 51, 71, 90, 97 and 103 at the breakout box.
l Is each resistance greater than 10,000 ohms?
Yes
The EAIR harness is OK. GO to «HM4».
No
SERVICE EAIR circuit for short. REMOVE breakout box. RECONNECT all components. COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
HM4 CHECK EAIR CIRCUIT FOR SHORT TO POWER AND GROUND
l Key off.
l Reconnect AIR bypass solenoid.
l Solid State Relay and PCM disconnected, breakout box installed.
l Measure resistance between Test Pin 70 and Test Pins 51, 71, 90, 97 and 103 at the breakout box.
Yes
EAIR circuit with AIR bypass solenoid OK. GO to «HM5».
No
REPLACE AIR bypass solenoid. REMOVE breakout box. RECONNECT components. COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
HM5 CHECK EAIR CIRCUIT FOR SHORT TO POWER AND GROUND
l Key off.
l Reconnect Solid State Relay.
Yes
If P0411 or P1411 are also present:
GO to «HM9».
All others:
REPLACE PCM. RECONNECT all components. COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
No
REPLACE Solid State Relay. REMOVE breakout box. RECONNECT components. COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
HM9 CHECK FOR VACUUM AT AIRD VALVES
l Key off.
l Reconnect PCM.
l Disconnect vacuum control line from the AIRD valve(s).
l Key on, engine running.
l After a 5 second delay, vacuum will be present between 30-90 seconds.
l Is vacuum present at the AIRD valve(s)?
Yes
GO to «HM10».
No
GO to «HM30».
HM10 CHECK AIRD VALVE(S) INTEGRITY
l Key off.
l Reconnect vacuum control line.
l Disconnect air tube from AIRD valve(s) outlet side.
l Cork off the air tube to prevent exhaust gases from escaping.
l Inspect AIRD valve(s) outlets for damage from hot exhaust gases. Service as necessary. Caution must be observed while performing this test.
l After a 5 second delay, air will be present between 30-90 seconds.
l Is air present from the AIRD valve(s)?
Yes
GO to Shop Manuals to service the exhaust tubes from the AIRD Valve to the exhaust manifold(s). COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
No
SERVICE hose from EAP to AIRD Valve. If OK, REPLACE the appropriate AIRD Valve(s). RECONNECT all components. COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
HM30 CHECK VACUUM HOSE INTEGRITY
l Key off.
l Check vacuum hose between AIRB solenoid and AIRD valve.
l Check for blockage and restrictions.
l Check for leaks and cracks.
l Check for kinks or disconnects.
l Are the above checks OK?
Yes
GO to «HM31».
No
REPLACE the vacuum line connecting the AIR bypass solenoid to AIRD valve(s). COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
HM31 CHECK AIR BYPASS SOLENOID ELECTRICAL OPERATION
l Connect Scan Tool.
l Enter Output Test Mode (OTM). Refer to «Section 2A», Diagnostic Methods.
l Connect DVOM to AIR bypass solenoid vehicle harness connector.
l Turn the outputs on, then turn outputs off while observing DVOM.
l Does EAIR circuit voltage cycle greater than .5 volt?
Yes
REMAIN in Output Test Mode. GO to «HM32».
No
GO to «HM33».
HM33 CHECK AIR BYPASS SOLENOID RESISTANCE
l Key off.
l Disconnect AIR bypass solenoid vehicle harness connector.
l Measure AIR bypass solenoid resistance.
l Is resistance between 50-100 ohms?
Yes
GO to «HM34»,
No
REPLACE AIR bypass solenoid. RECONNECT all components. COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
HM34 CHECK VPWR CIRCUIT VOLTAGE
l Measure voltage between VPWR at the AIR bypass solenoid vehicle harness connector and battery ground.
Yes
GO to «HM35».
No
SERVICE open VPWR circuit. RECONNECT AIR bypass. COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
HM35 CHECK CONTINUITY OF EAIR CIRCUIT
l Key off.
l Disconnect Solid State Relay.
l Measure resistance between Test Pin 70 at the breakout box and EAIR circuit at the AIR solenoid bypass vehicle harness connector and at the Solid State Relay vehicle harness connector.
Yes
GO to «HM36».
No
SERVICE open EAIR circuit. RECONNECT components. COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
HM36 CHECK EAIR CIRCUIT FOR SHORT TO GROUND
l Key off.
l Breakout box installed, PCM disconnected.
l Disconnect Scan Tool.
l Measure resistance between Test Pin 70 and Test Pins 51, 76 and 91 at the breakout box.
Yes
GO to «HM37».
No
SERVICE short to ground. RECONNECT components. COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
HM37 CHECK EAIR CIRCUIT FOR SHORT TO POWER
l Key off.
l Measure resistance between Test Pin 70 and Test Pins 71 and 97 at the breakout box.
Yes
REPLACE PCM. RECONNECT components. COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
No
SERVICE short to power. RECONNECT components. COMPLETE PCM Reset to clear DTCs (REFER to Section 2A, «Powertrain Control Module (PCM) Reset»). RERUN «Quick Test».
Often I have found that this code gets triggered by folks not tightening their gas caps after fill up. Try doing it and have the code cleared before you junp into anything more complex.
what does a p0412 have to do with the evap system?
p0455 is the typical gas cap off code.
i was talking to lincoln lurker the other day at work about how great copy and paste is with a little help from FMC dealer lol
you ever on the tech to tech forum?
i spend quite a bit of time on there. love the stupid service writers and customers.
Alright guys, I'm getting this same code (P0412). The problem is, I don't understand all the damn acronyms to try to troubleshoot this thing. Any chance you ford techs can help decipher???
Possible causes:
-- Damaged PCM.
l Key off.
l Disconnect SSR.
Yes
No
GO to «HM6».
Where is HM6 guys???
Nevermind, I double checked the fuses with a meter with the car running and found the blow 30 amp fuse under the hood. Jumped it and tested the SSR plug, worked great after that. Got rid of my code!
My thermactor pump was full of water. The intake tube on it had lost it's cap and was exposed to weather for two years. The more I shook it, the more water came out. Replaced the pump and fuse and whola!
