codes
mcafferty
Lakeville
2001 LS V8
I have been getting a check eng but i guess it called emission light. the lite goes on and stays on for a few days to a week and then goes off. the car does seem to idle a litte odd sometimes. I took my predator tuner from my lightning and looked at the codes. there were two:
P0153
02 Circuit slow response (Bank 2, Sensor 1)
P0171
System to lean (Bank 1)
Is this a bad O2 sensor and if so how many do these cars have and which one is bank 2 sensor 1?
I would think the second code is due to the first code. any help would be great. thanks...Mac
Bank 1 is the passenger side; Bank 2, Sensor 1 is the "front" O2 sensor on the driver's side. I don't remember if it's in the cat or in the downpipe.
thanks guys
does bank 1 mean the side with the #1 cylinder? does anyone have a firing order diagram?
The pre-cat snesors are the ones that provide feedback data on A/F mix. The post cats provide insight as to how well the cats are performing
just replaced the two front O2 they were only $45 each. I also found the cracked line that was after the maf fixed that and cleared all the codes, changed oil and cleaned the maf. took it on a 100 mile cruse no codes no problems she runs nice and smooth again. thanks for the help guys
thanks guys
The firing order is posted around here somewhere, and yes, cylinder #1 is in bank #1; both are on the passenger side, as noted above.
