Codes: P04b4 P2bed
91 LSC SE
Canada
Hi Everyone,
CEL came on and the reader provided codes below. I did some searching and found descriptions below. M8 drives fine, i do not see much of a difference from last week, although I have thought I smelled fuel for a while, but didn't see any leaks and thoguht it was the small exhaust leak:
Found:
P04b4: Refuelling vapour control valve - valve stuck closed
and this:
P04B4 Code Meaning :
P 0 4 b 4
o: Intake Valve Control Solenoid Circuit Low Fuel Temperature Sensor
B: Circuit Range/Performance
4: Clutch Position Sensor Circuit Malfunction
and stated: However your vehicle's manufacturer may have a different definition for the P04B4 OBD-II Trouble Code.
P2bed: Error P2BED definition not found!
and
P2BED Code Meaning :
P 2 b e d
OBD Fuel And Air Metering (Injector Circuit Malfunctions Only)
P1518 - this is the IMRC I had this code a few years ago and with a bit of penetrating oil was an easy fix. Help with the other two would be appreciated!
so no one has has these two codes? Searches here only listed details on 1815 and I posted on that as well with pics to fix the IMRC issue.
Hasn't anyone smelled gas in the interior?
P04b4
P2bed
