Hi all. my car is still giving me a hard time. 2002 3.9 150,000 miles. i had a misfire code. put new coils and plugs. no more misfire code. now 2 more codes. the car has always had to crank for around 10 sec before it fired. i was thinking it was injectors because when it finely fires it gets a puff of smoke out the pipes and smells strong like fuel. the CEL is not on. my moms car is running like crap and i tried scanning it and got nothing. and it was saying no monitors were ready. so just to check the scanner i plugged it in to the LS and it puled 2 codes p0320 and p0340. and just to be clear the CEL is not on. a search of the ls section pulled up a list of codes and this is what i got for the 2 codes.
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0340 Camshaft Position Sensor Circuit Malfunction
can this just be a bad sensor or can a loose cam chain throw these codes? on top of being hard to start if you punch it she craps out / sputters for a second and then cleans up and pulls hard. and some times sitting at a light it will stumble for a second and the idle fine. thanks for any help you can give.
