Codes And DTC's
2002_lincolnLS
Custom User Title
canton
Here is a complete list of all of the codes and DTC's.
To find your DTC simply press Control "F" and enter your code into the Dialog box to search the code.
Also we have the PATS light codes listed that i could find.
Symptom: The vehicle starts and runs for longer than 1 second, then stalls.
This is not a passive anti-theft system (PATS) issue. PATS never disables a running engine.
code 12
This appears to be a bad transceiver in the steering col. The only test is to replace with a known good unit. The part number is XW4Z 15607-AA
Code 16
indicates a communications issue between the cluster (where the PATS function is) and the PCM. The few cases of it that I have heard of worked out to be a bad PCM relay or corroded relay socket. I'd start by checking the relays.
CODES
[*]P1000 OBD System Readiness Test Not Complete
[*]P1001 KOER Test Cannot Be Completed
[*]P1039 Vehicle Speed Signal Missing or Improper
[*]P1051 Brake Switch Signal Missing or Improper
[*]P1100 Mass Air Flow Sensor Intermittent
[*]P1101 Mass Air Flow Sensor Out of Self-Test Range
[*]P1105 Dual Alternator Upper Fault
[*]P1106 Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
[*]P1107 Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low
Voltage
[*]P1108 Dual Alternator Battery Lamp Circuit Malfunction
[*]P1109 IAT - B Sensor Intermittent
[*]P1111 System Pass
[*]P1112 Intake Air Temperature Sensor Intermittent
[*]P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input
[*]P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage/IAT - B Circuit High Input
[*]P1116 Engine Coolant Temperature Sensor is Out of Self-Test Range
[*]P1117 Engine Coolant Temperature Sensor Intermittent
[*]P1118 Manifold Absolute Temperature Circuit Low Input
[*]P1119 Manifold Absolute Temperature Circuit High Input
[*]P1120 Throttle Position Sensor Out of Range
[*]P1121 Throttle Position Sensor Inconsistent with Mass Air Flow Sensor
[*]P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
[*]P1123 Throttle Position Sensor In Range But Higher Than Expected
[*]P1124 Throttle Position Sensor Out of Self-Test Range
[*]P1125 Throttle Position Sensor Intermittent
[*]P1127 Exhaust Not Warm Enough - Downstream O2 Sensor Not Tested - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1128 Upstream Heated Oxygen Sensor Signals Reversed - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1129 Downstream Heated Oxygen Sensor Signals Reversed - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1130 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank 1 - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank 1 - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank 1 - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1133 Bank 1 Fuel Control Shifted Lean - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1134 Bank 1 Fuel Control Shifted Rich - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1135 Pedal Position Sensor A Circuit Intermittent
[*]P1137 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank 1 - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1138 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank 1 - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1139 Water In Fuel Indicator Circuit Malfunction
[*]P1140 Water In Fuel Condition
[*]P1141 Fuel Restriction Indicator Circuit Malfunction
[*]P1142 Fuel Restriction Condition
[*]P1150 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank 2 - Read Our Article on Oxygen
[*]P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank 2 - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank 2 - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1153 Bank 2 Fuel Control Shifted Lean - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1154 Bank 2 Fuel Control Shifted Rich - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1155 Alternative Fuel Controller
[*]P1157 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank 2 - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1158 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank 2 - Read Our Article on Oxygen Sensor Codes For Help With This Lincoln Check Engine Light Code
[*]P1168 Fuel Rail Sensor In-Range Low Failure
[*]P1169 Fuel Rail Sensor In-Range High Failure
[*]P1170 ESO - Engine Shut Off Solenoid Fault
[*]P1171 Rotor Sensor Fault
[*]P1172 Rotor Control Fault
[*]P1173 Rotor Calibration Fault
[*]P1174 Cam Sensor Fault
[*]P1175 Cam Control Fault
[*]P1176 Cam Calibration Fault
[*]P1177 Synchronization Fault
[*]P1180 Fuel Delivery System Malfunction - Low
[*]P1181 Fuel Delivery System Malfunction - High
[*]P1183 Engine Oil Temperature Circuit Malfunction
[*]P1184 Engine Oil Temperature Out Of Self Test Range
[*]P1185 FTS High - Fuel Pump Temperature Sensor High
[*]P1186 FTS Low - Fuel Pump Temperature Sensor Low
[*]P1187 Variant Selection
[*]P1188 Calibration Memory Fault
[*]P1189 Pump Speed Signal Fault
[*]P1190 Calibration Resistor Out Of Range
[*]P1191 Key Line Voltage
[*]P1192 Voltage External
[*]P1193 EGR Drive Overcurrent
[*]P1194 ECU A/D Converter
[*]P1195 SCP HBCC Failed To Initialize
[*]P1196 Key Off Voltage High
[*]P1197 Key Off Voltage Low
[*]P1198 Pump Rotor Control Underfueling
[*]P1209 Injector Control Pressure System Fault
[*]P1210 Injector Control Pressure Above Expected Level
[*]P1211 Injector Control Pressure Sensor Above / Below Desired
[*]P1212 Injector Control Pressure Not Detected During Crank
[*]P1213 Start Injector Circuit Malfunction
[*]P1214 Pedal Position Sensor B Circuit Intermittent
[*]P1215 Pedal Position Sensor C Circuit Low Input
[*]P1216 Pedal Position Sensor C Circuit High Input
[*]P1217 Pedal Position Sensor C Circuit Intermittent
[*]P1218 CID High
[*]P1219 CID Low
[*]P1220 Series Throttle Control Fault
[*]P1221 Traction Control System Malfunction
[*]P1222 Traction Control Output Circuit Malfunction
[*]P1223 Pedal Demand Sensor B Circuit High Input
[*]P1224 Throttle Position Sensor B Out of Self-Test Range
[*]P1227 Wastegate Failed Closed (Over Pressure)
[*]P1228 Wastegate Failed Open (Under Pressure)
[*]P1229 Intercooler Pump Driver Fault
[*]P1230 Open Power to Fuel Pump Circuit
[*]P1231 High Speed Fuel Pump Relay Activated
[*]P1232 Low Speed Fuel Pump Primary Circuit Failure
[*]P1233 Fuel Pump Driver Module Off-Line
[*]P1234 Fuel Pump Driver Module Off-Line
[*]P1235 Fuel Pump Control Out of Range
[*]P1236 Fuel Pump Control Out of Range
[*]P1237 Fuel Pump Secondary Circuit Fault
[*]P1238 Fuel Pump Secondary Circuit Fault
[*]P1239 Speed Fuel Pump Positive Feed Fault
[*]P1243 Second Fuel Pump Faulty or Ground Fault
[*]P1244 Alternator Load Input Failed High
[*]P1245 Alternator Load Input Failed Low
[*]P1246 Alternator Load Input Failed
[*]P1247 Turbo Boost Pressure Low
[*]P1248 Turbo Boost Pressure Not Detected
[*]P1249 Wastegate Control Valve Performance
[*]P1250 Lack of Power to FPRC Solenoid
[*]P1252 Pedal Correlation PDS1 and LPDS High
[*]P1253 Pedal Correlation PDS1 and LPDS Low
[*]P1254 Pedal Correlation PDS2 and LPDS High
[*]P1255 Pedal Correlation PDS2 and LPDS Low
[*]P1256 Pedal Correlation PDS1 and HPDS
[*]P1257 Pedal Correlation PDS2 and HPDS
[*]P1258 Pedal Correlation PDS1 and PDS2
[*]P1260 Theft Detected - Engine Disabled
[*]P1261 Cylinder #1 High To Low Side Short
[*]P1262 Cylinder #2 High To Low Side Short
[*]P1263 Cylinder #3 High To Low Side Short
[*]P1264 Cylinder #4 High To Low Side Short
[*]P1265 Cylinder #5 High To Low Side Short
[*]P1266 Cylinder #6 High To Low Side Short
[*]P1267 Cylinder #7 High To Low Side Short
[*]P1268 Cylinder #8 High To Low Side Short
[*]P1270 Engine RPM or Vehicle Speed Limiter Reached
[*]P1270 Engine RPM Or Speed Limiter Reached
[*]P1271 Cylinder #1 High To Low Side Open
[*]P1272 Cylinder #2 High To Low Side Open
[*]P1273 Cylinder #3 High To Low Side Open
[*]P1274 Cylinder #4 High To Low Side Open
[*]P1275 Cylinder #5 High To Low Side Open
[*]P1276 Cylinder #6 High To Low Side Open
[*]P1277 Cylinder #7 High To Low Side Open
[*]P1278 Cylinder #8 High To Low Side Open
[*]P1280 Injection Control Pressure Out Of Range Low
[*]P1281 Injection Control Pressure Out Of Range High
[*]P1282 Excessive Injection Control Pressure
[*]P1283 IPR Circuit Failure
[*]P1284 Aborted KOER - ICP Failure
[*]P1285 Cylinder head over temp sensed
[*]P1286 Fuel Pulse In Range But Lower Than Expected
[*]P1287 Fuel Pulse In Range But Higher Than Expected
[*]P1288 Cylinder Head Temperature Sensor Out of Self-Test Range
[*]P1289 Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range
[*]P1290 Cylinder Head Temperature Sensor Signal Less Than Self-Test Range
[*]P1291 Injector High Side Short To GND Or VBATT - Bank 1
[*]P1292 Injector High Side Short To GND Or VBATT - Bank 2
[*]P1293 Injector High Side Open - Bank 1
[*]P1294 Injector High Side Open - Bank 2/Target idle not reached
[*]P1295 Multi-faults - Bank 1 - With Low Side Shorts
[*]P1296 Multi-faults - Bank 2 - With Low Side Shorts
[*]P1297 Injector High Sides Shorted Together
[*]P1298 IDM Failure
[*]P1299 Cylinder Head Temperature Sensor Detected Engine Overheating Condition
http://www.lincolnvscadillac.com/showthread.php?t=8745&highlight=P1100
[*]P1300 Boost Calibration Fault
[*]P1301 Boost Calibration High
[*]P1302 Boost Calibration Low
[*]P1303 EGR Calibration Fault - Read Our Article on EGR Valve Codes For Help With This Lincoln Check Engine Light
Code
[*]P1304 EGR Calibration High
[*]P1305 EGR Calibration Low
[*]P1306 Kickdown Relay Pull - In Circuit Fault
[*]P1307 Kickdown Relay Hold Circuit Fault
[*]P1308 A/C Clutch Circuit Fault
[*]P1309 Misfire Detection Monitor Not enabled
[*]P1316 Injector Circuit / IDM Codes Detected
[*]P1317 Injector Circuit / IDM Codes Not Updated
[*]P1340 Camshaft Position Sensor B Circuit Malfunction
[*]P1351 Ignition Diagnostic Monitor Circuit Input Fault
[*]P1352 Ignition Coil A - Primary Circuit Fault
[*]P1353 Ignition Coil B - Primary Circuit Fault
[*]P1354 Ignition Coil C - Primary Circuit Fault
[*]P1355 Ignition Coil D - Primary Circuit Fault
[*]P1356 Loss of Ignition Diagnostic Module Input to PCM
[*]P1357 Ignition Diagnostic Monitor Pulsewidth Not Defined
[*]P1358 Ignition Diagnostic Monitor Signal Out of Self-Test Range
[*]P1359 Spark Output Circuit Fault
[*]P1360 Ignition Coil A Secondary Circuit Malfunction
[*]P1361 Ignition Control (IC) Circuit Low Voltage
[*]P1362 Ignition Coil C Secondary Circuit Malfunction
[*]P1363 Ignition Coil D Secondary Circuit Malfunction
[*]P1364 Ignition Coil Primary Circuit Fault
[*]P1365 Ignition Coil Secondary Circuit Failure
[*]P1369 Engine Temperature Light Monitor Failure
[*]P1380 VCT Solenoid Valve Circuit Short or Open
[*]P1381 Cam Timing Advance is excessive
[*]P1383 Cam Timing Advance is excessive
[*]P1385 Variable Cam Timing Solenoid B Malfunction
[*]P1386 Variable Cam Timing Overadvanced (Bank #2)
[*]P1388 Variable Cam Timing Overretarded (Bank #2)
[*]P1389 Glow Plug Circuit High Side Low Input
[*]P1390 Octane Adjust Out of Self-Test Range
[*]P1391 Glow Plug Circuit Low Input (Bank #1)
[*]P1392 Glow Plug Circuit High Input (Bank #1)
[*]P1393 Glow Plug Circuit Low Input (Bank #2)
[*]P1394 Glow Plug Circuit High Input (Bank #2)
[*]P1395 Glow Plug Monitor Fault (Bank #1)
[*]P1396 Glow Plug Monitor Fault (Bank #2)
[*]P1397 System Voltage Out Of Self Test Range
[*]P1399 Glow Plug Circuit High Side, High Input
[*]P1400 Differential Pressure Feedback Electronic Sensor Circuit Low Voltage - Read Our Article on EGR System
Diagnosis For Help With This Lincoln Check Engine Light Code
[*]P1401 Differential Pressure Feedback Electronic Sensor Circuit High Voltage - Read Our Article on EGR System
[*]P1402 EGR Metering Orifice Restricted - Read Our Article on EGR System Diagnosis For Help With This Lincoln Check
Engine Light Code
[*]P1403 Differential Pressure Feedback Electronic Sensor Hoses Reversed - Read Our Article on EGR System Diagnosis For Help With This Lincoln Check Engine Light Code
[*]P1404 IAT - B Circuit Malfunction/ Exhaust Gas Recirculation Closed Position Performance
[*]P1405 Differential Pressure Feedback Electronic Sensor Circuit Upstream Hose - Read Our Article on EGR System
[*]P1406 Differential Pressure Feedback Electronic Sensor Circuit Downstream Hose - Read Our Article on EGR System Diagnosis For Help With This Lincoln Check Engine Light Code
[*]P1407 EGR No Flow Detected - Read Our Article on EGR System Diagnosis For Help With This Lincoln Check Engine Light Code
[*]P1408 EGR Flow Out of Self-Test Range - Read Our Article on EGR System Diagnosis For Help With This Lincoln Check Engine Light Code
[*]P1409 EGR Vacuum Regulator Circuit malfunction - Read Our Article on EGR System Diagnosis For Help With This Lincoln Check Engine Light Code
[*]P1409 Electronic Vacuum Regulator Control Circuit Fault - Read Our Article on EGR System Diagnosis For Help With This Lincoln Check Engine Light Code
[*]P1410 EGR Barometric Pressure Sensor VREF Voltage - Read Our Article on EGR System Diagnosis For Help With This Lincoln Check Engine Light Code
[*]P1411 Secondary Air is Not being diverted
[*]P1413 Secondary Air Injection System Monitor Circuit Low Voltage
[*]P1414 Secondary Air Injection System Monitor Circuit High Voltage
[*]P1431 Misfire Monitor Disabled, Unable to Learn Trigger Wheel Profile
[*]P1442 Secondary Air Injection System Monitor Circuit High Voltage
[*]P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve Fault
[*]P1444 Purge Flow Sensor Circuit Input Low
[*]P1445 Purge Flow Sensor Circuit Input High
[*]P1450 Inability of Evaporative Emission Control System to Bleed Fuel Tank
[*]P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction
[*]P1452 Inability of Evaporative Emission Control System to Bleed Fuel Tank
[*]P1455 Substantial Leak or Blockage in Evaporative Emission Control System
[*]P1457 Unable To Pull Vacuum In Tank
[*]P1460 Wide Open Throttle Air Conditioning Cutoff Circuit malfunction
[*]P1461 Air Conditioning Pressure Sensor Circuit Low Input
[*]P1462 Air Conditioning Pressure Sensor Circuit high Input
[*]P1463 Air Conditioning Pressure Sensor Insufficient Pressure change
[*]P1464 ACCS to PCM High During Self-Test
[*]P1465 A/C Relay Circuit Malfunction
[*]P1466 A/C Refrigerant Temperature Sensor/Circuit Malfunction
[*]P1469 Low Air Conditioning Cycling Period
[*]P1473 Fan Secondary High with Fans Off
[*]P1474 Low Fan Control Primary Circuit
[*]P1479 High Fan Control Primary Circuit
[*]P1480 Fan Secondary Low with Low Fans On
[*]P1481 Fan Secondary Low with High Fans On
[*]P1482 SCP
[*]P1483 Power to Cooling Fan Exceeded Normal Draw
[*]P1484 Variable Load Control Module Pin 1 Open
[*]P1485 EGRV Circuit Malfunction
[*]P1500 Vehicle Speed Sensor Intermittent
[*]P1501 Programmable Speedometer & Odometer Module/Vehicle Speed Sensor Intermittent Circuit-failure
[*]P1502 Invalid or Missing Vehicle Speed Message or Brake Data
[*]P1504 Intake Air Control Circuit malfunction
[*]P1505 Idle Air Control System at Adaptive Clip
[*]P1506 Idle Air Control Over Speed Error
[*]P1507 Idle Air Control Under Speed Error
[*]P1512 Intake Manifold Runner Control Stuck Closed
[*]P1513 Intake Manifold Runner Control Stuck Closed
[*]P1516 Intake Manifold Runner Control Input Error
[*]P1517 Intake Manifold Runner Control Input Error
[*]P1518 Intake Manifold Runner Control Fault - Stuck Open
[*]P1519 Intake Manifold Runner Control Stuck Open
[*]P1520 Intake Manifold Runner Control Circuit Fault
[*]P1519 Intake Manifold Runner Control Fault - Stuck Closed
[*]P1520 Intake Manifold Runner Control Fault
[*]P1530 Open or Short to A/C Compressor Clutch Circuit
[*]P1531 Invalid Test - Accelerator Pedal Movement
[*]P1532 IMCC Circuit Malfunction, Bank B
[*]P1533 AAI Circuit Malfunction
[*]P1534 Inertia Switch Activated
[*]P1536 Parking Brake Switch Circuit Failure
[*]P1537 Intake Manifold Runner Control Stuck Open
[*]P1538 Intake Manifold Runner Control Stuck Open
[*]P1539 Power to A/C Compressor Clutch Circuit Exceeded Normal Current Draw
[*]P1549 Intake Manifold Temperature Valve Vacuum Actuator Connection
[*]P1550 Power Steering Pressure Sensor Out of Self-Test Range
[*]P1565 Speed Control Command Switch Out of Range High
[*]P1566 Speed Control Command Switch Out of Range Low
[*]P1567 Speed Control Output Circuit Continuity
[*]P1568 Speed Control Unable to Hold Speed
[*]P1572 Brake Pedal Switch Circuit Malfunction
[*]P1573 Throttle Position Not Available
[*]P1574 Throttle Position Sensor Disagreement btwn Sensors
[*]P1575 Pedal Position Out of Self Test Range
[*]P1576 Pedal Position Not Available
[*]P1577 Pedal Position Sensor Disagreement btwn Sensors
[*]P1578 ETC Power Less Than Demand
[*]P1579 ETC In Power Limiting Mode
[*]P1580 Electronic Throttle Monitor PCM Override
[*]P1581 Electronic Throttle Monitor Malfunction
[*]P1582 Electronic Throttle Monitor Data Available
[*]P1583 Electronic Throttle Monitor Cruise Disable
[*]P1584 Throttle Control Detected ETB Malfunction
[*]P1585 Throttle Control Unit Malfunction
[*]P1586 Throttle Control Unit Throttle Position Malfunction
[*]P1587 Throttle Control Unit Modulated Command Malfunction
[*]P1588 Throttle Control Unit Detected Loss of Return Spring
[*]P1589 Throttle Control Unit Unable To Control Desired Throttle Angle
[*]P1600 Loss of KAM Power - Open Circuit
[*]P1605 PCM Keep Alive Memory Test Error
[*]P1625 Voltage to Vehicle Load Control Module Fan Circuit Not detected
[*]P1626 Voltage to Vehicle Load Control Module Circuit Not detected
[*]P1634 Data Output Link Circuit Failure
[*]P1635 Tire / Axle Ratio Out of Acceptable Range
[*]P1636 Inductive Signature Chip Communication Error
[*]P1639 Vehicle ID Block Corrupted or Not Programmed
[*]P1640 Powertrain DTCs Available in Another Module
[*]P1641 Fuel Pump Primary Circuit Failure
[*]P1642 Fuel Pump Monitor Circuit High Input
[*]P1643 Fuel Pump Monitor Circuit Low Input
[*]P1644 Fuel Pump Speed Control Circuit Malfunction
[*]P1650 Power Steering Pressure Switch Out of Self-Test Range
[*]P1651 Power Steering Pressure Switch Input Fault
[*]P1656 CAN Link PCM - PCM Circuit - Network
[*]P1657 CAN Link Chip Malfunction
[*]P1660 Output Circuit Check Signal High
[*]P1661 Output Circuit Check Signal Low
[*]P1662 IDM_EN Circuit Failure
[*]P1663 Fuel Demand Command Signal Circuit Malfunction
[*]P1667 CI Circuit Malfunction
[*]P1668 PCM - IDM Communications Error
[*]P1670 Electronic Feedback Signal Not Detected
[*]P1690 Wastegate Solenoid Circuit Malfunction
[*]P1700 Transmission system problems
[*]P1701 Reverse Engagement Error
[*]P1702 Transmission system problems
[*]P1703 Brake On/Off Switch Out of Self-Test Range
[*]P1704 Transmission system problems
[*]P1705 Manual Lever Position Sensor Out of Self-Test Range
[*]P1706 High Vehicle Speed Observed in Park
[*]P1707 Transfer Case Neutral Indicator Hard Fault Present
[*]P1709 Park or Neutral Position Switch Out of Self-Test Range
[*]P1710 Transmission system problems
[*]P1711 Transmission Fluid Temperature Sensor Out of Self-Test Range
[*]P1712 Trans Torque Reduction Request Signal Malfunction
[*]P1713 TFT Sensor In Range Failure Low Value
[*]P1714 SSA Inductive Signature Malfunction
[*]P1715 SSB Inductive Signature Malfunction
[*]P1716 SSC Inductive Signature Malfunction
[*]P1717 SSD Inductive Signature Malfunction
[*]P1718 TFT Sensor In Range Failure High
[*]P1720 Vehicle Speed (Meter) Circuit Malfunction
[*]P1721 Gear 1 Incorrect Ratio
[*]P1722 Gear 2 Incorrect Ratio
[*]P1723 Gear 3 incorrect Ratio
[*]P1724 Gear 4 Incorrect Ratio
[*]P1725 Insufficient Engine Speed Increase During Self Test
[*]P1726 Insufficient Engine Speed Decrease During Self Test
[*]P1727 Coast Clutch Solenoid Inductive Signature Malfunction
[*]P1728 Transmission Slip Error
[*]P1729 4x4 Low Switch Error
[*]P1731 1-2 Shift Malfunction
[*]P1732 2-3 Shift Malfunction
[*]P1733 3-4 Shift Malfunction
[*]P1740 Transmission system problems
[*]P1741 Torque Converter Clutch Control Error
[*]P1742 Torque Converter Clutch Solenoid Faulty
[*]P1743 Torque Converter Clutch Solenoid Faulty
[*]P1744 Torque Converter Clutch System Stuck in Off Position
[*]P1745 Transmission system problems
[*]P1746 Electronic Pressure Control Solenoid A - Open Circuit
[*]P1747 Electronic Pressure Control Solenoid A- Short Circuit
[*]P1748 EPC Malfunction
[*]P1749 Electronic Pressure Control Solenoid Failed Low
[*]P1751 Shift Solenoid A Performance
[*]P1754 Coast Clutch Solenoid Circuit malfunction
[*]P1756 Shift Solenoid B Performance
[*]P1760 Transmission system problems
[*]P1761 Shift Solenoid C Performance
[*]P1762 Overdrive Band Failed Off
[*]P1766 Shift Solenoid D Performance
[*]P1767 Torque Converter Clutch Circuit Malfunction
[*]P1768 Performance / Normal / Winter Mode Input Malfunction
[*]P1770 Clutch Solenoid Circuit Malfunction
[*]P1779 Transmission Control Indicator Lamp Circuit Malfunction
[*]P1780 Transmission Control Switch Circuit is Out of Self-Test Range
[*]P1781 4x4 Low Switch is Out of Self-Test Range
[*]P1782 P/ES Circuit Out Of Self Test Range
[*]P1783 Transmission Over-Temperature Condition
[*]P1784 Transmission Mechanical Failure - First And Reverse
[*]P1785 Transmission Mechanical Failure - First And Second
[*]P1786 3-2 Downshift Error
[*]P1787 2-1 Downshift Error
[*]P1788 Pressure Control Solenoid "B" Open Circuit
[*]P1789 Pressure Control Solenoid "B" Short Circuit
[*]P1795 Idle Switch Circuit Malfunction
[*]P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure
[*]P1806 Transmission 4-Wheel Drive High Indicator Short Circuit To Battery
[*]P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure
[*]P1810 TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery
[*]P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure
[*]P1815 Transmission 4-Wheel Drive Mode Select Short Circuit To Ground
[*]P1819 Transmission Neutral Safety Switch Short Circuit To Ground
[*]P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure
[*]P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery
[*]P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure
[*]P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery
[*]P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure
[*]P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
[*]P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
[*]P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery
[*]P1838 Transmission Transfer Case Shift Motor Circuit Failure
[*]P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure
[*]P1850 Transmission Transfer Case Contact Plate 'B' Circuit Failure
[*]P1854 Transmission Transfer Case Contact Plate 'C' Circuit Failure
[*]P1858 Transmission Transfer Case Contact Plate 'D' Circuit Failure
[*]P1866 Transmission Transfer Case System Concern - Servicing Required
[*]P1867 Transmission Transfer Case Contact Plate General Circuit Failure
[*]P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure
[*]P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery
[*]P1881 Engine Coolant Level Switch Circuit Failure, GEM
[*]P1882 Engine Coolant Level Switch Circuit Short to Ground
[*]P1883 Engine Coolant Level Switch Circuit Failure, GEM
[*]P1884 Engine Coolant Level Lamp Circuit Short to Ground
[*]P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit
[*]P1900 Output Shaft Speed (OSS) Circuit Intermittent Malfunction
[*]P1901 Turbine Shaft Speed (TSS) Circuit Intermittent Malfunction
[*]P1902 Kickdown Solenoid Relay Control Circuit
[*]P1903 Kickdown Solenoid Circuit Low Voltage
[*]P1904 Kickdown Solenoid Circuit High Voltage
[/LIST]
So I have this huge list I want to try and find any threads related to the Codes that I can, If anyone whats to take a section and run some searches just pose the ones you can look up and then email me the thread URL and code number and I will edit the post.
Thanks guys.
well I want to go one step further and offer solutions to those codes as well as make it look more clean
Where is this said article?
This is a good tread, im having problems with so codes po460,p1000,p1233,c1315,po703, and 1565. I will post my findings.
