- Front Driver bearing
- Front Passenger bearing
- Front Driver [upper] Ball Joint
- Tie rod end
Bad luck, random part quality problem, harsh pot hole impacts? Using bigger than 18" rims?
I've had one front wheel bearing failure (with lots of warning so that it was replaced before it was anything more than a noise problem). It happens...
Stock Rims. Paved Roads. Mixed hwy / city driving.
- 8 Coil packs
They are not coil packs. They are COPs. There is a difference. Unfortunately, COPs are a maintenance item on the LS. They shouldn't be, but we all know that they are. Get over it. I've replaced all the COPs and plugs on both of my LSes, one at about 70K, and the other at about 85K. I did this at the first sign of misfire so that I wouldn't have to replace my cats.
One of the many, many common issues making this car unreliable...
- Driver window motor
- Rear Driver window motor
Odd, but I did have one window motor fail on one of my Grand Marquis once. I've had to replace a window regulator on both LSes, but I'd had some of those fail on every car I'd had. (I tend to keep cars to a fairly high mileage.) Window regulators are wear items.
Canadian winters? Cold climate is just brutal on anything. Still had 2 fail regardless
- Alternator
- Clock Spring
These are wear items too. I've haven't had to replace either in either of my LSes, but I've certainly worn out alternators and clocksprings in some of my other cars.
Replaced mine on the 2002 around 160k Kilometers (158 miles?) Hasn't been an issue on my Friends Acura's
And is it listed in the hand book as a maintenance schedule?
- Front Passenger caliper
- Rear passenger caliper
Really? Why not complain about replacing brake pads and rotors too. These are wear items and your mileage will vary. Same story as before. I haven't yet worn out a caliper on either LS, but I've had calipers to stick or leak on other cars and had to replace them.
Calipers were not warn, They leaked. Seal failures on both. Don't see how this is regular maintenance. A Third caliper is now leaking.
- Windshield (Twice, Cracked from pressure. Fail Ford.)
Not sure how that's Ford's fault. I've had both windshields replaced due to rocks hitting them. My insurance fully paid for it. Several years ago (on another car), I went through about four windshields in a year. Finally, I insisted on using a different company to replace the fourth one (the insurance did by then too). The guy that replaced the first one had left a piece of glass down in the calking and the other people missed it too. I guess that for Ford's fault?
Specified: The metal under the shield swelled from corrosion. Glass guys informed me this is NOT supposed to happen. Its sealed. The swelling applied pressure and snapped the shield. Glass guy sanded, and primed. Advised me it will happen again, nothing I can do. Also they informed me the previous Glass was replaced correctly. Just simply a Flaw in manufacturing.
- Serpentine belt
Really? That's scheduled maintenance. Check at 100K miles and replace by 150K miles. I've replaced mine when doing cooling system work, so they only made it half as long. However, the ones I replaced still looked really good and I think I could have reused them. Being interested in keeping things reliable, I didn't. It used to be that you were doing good to get 30K miles out of a belt.
That one you got me.
