... including TRANSMISSION probs. don-ohio
Blowing smoke up people's asses again are we?
I'll explain but for others as you wouldn't understand nor care to understand anyhow.
Failing/misfiring coils do NOT create transmission problems as stated. Nothing wrong with trans. Nothing within the trans needs fixing.
What happens is the failing and misfiring coils generate EMI, Electric Magnetic Interference toward the nearby PCM, it creates havoc on this delicate little item we know as the COMPUTER, that controls the power train amongst other operations.
Specifically a marginal failing coil #4 which is closest to the nonshielded or not enough shielded PCM, will irritate it to the point where it will throw a bad throttle body code causing it to go into failsafe mode and if you continue to drive it like that it will and can begin to buck the transmission shifts. It'll bang in and out of gears but there is not a transmission problem per say. Clearly not good for it obviously.
Suggested is to not drive it like that unless you have a wallet to support such a dumb move. Restarting the car can and will clear the failsafe but the cycle continues as the EMI persists until the coil issue is resolved.
I picked up an 04 LSE on the cheap because the guy was frustrated with the dealership after having been talked into 2700$ worth of work that included a new throttle body. It continued to go into failsafe mode. Having already scanned it and knowing of this problem and having 8 brand new Visteon coils on the shelves back home, I bought it, slapped a borrowed dealer plate on it and got it home gently on the back roads without hitting it into failsafe mode. Anything over 60kmh or too much throttle would set it off again.
Put a known good older OEM coil on #4 and problem went away immediately, no transmission problems what so ever.
Replaced all coils and all plugs and hasn't given me any troubles since. To date the transmission has been fine with the exception as of late I've got a slight bang in and out of park at times, which I know to be the shift solenoid or possibly the PCM needs to be reworked. I blame my excessive lead footed beating on it. Not any fault of failing coil issues.
Anyhow .... whatever .... not even looking at the upcoming silly rebuttal. LOL
