Clockspring
remogaggi
Baltimore
My horn has stopped working, as well as my cruise control and almost all of the audio controls buttons in the steering wheel. Now, i have the airbag sensor beeps coming on when i turn on my car. i know its the clockspring but if i get the dealership to replace to the clockspriing will these problems be solved, or do they have to rewire everything and install additional parts.
I already have the clockspring just need to get it installed. Is there a write up anywhere on how to do this, preferably with pictures.
Its a pretty basic install, did mine with little effort. Just make sure you pull the battery positive first. When you pull the steering wheel off and cover you will see it. Might help you make sure the wheel is fully extended so its better exposed. It is a simple pop and plug situation.
It def fixed all the problems you described.
