climate control
tda13
Quincy
Hey, I have a problem with my climate control on my 97. At 60, it is max cold, but if you turn it up 1 setting (65 being the next setting) it is max hot.
I have max cold and max hot... no in between.
Any ideas?
Thanks
Tim
Is it cold outside where ya are? The automatic climate control tries to make the cabin 65 degrees, not the air coming out. The exceptions being that 60 = no heat or adjustments at all and 90 (is the the max?) full heat no adjustments.
Yes, it is cold (Western Illinois), but I had the same problem during the summer. During the summer it was not as bad.... I could deal with it.
The problem is I have two settings.... Really freakin hot or really freakin cold. There is no in between no matter how I set it....65, 70, 72, or what ever is actually 90... 60 is -30.
Tim
Tim
Thought I would follow up by saying I know how it is suppose to work... I have the viii and a Navigator.
