clear turn signal markers
sold out until late march... I have a question, if i remove the amber lense will an amber turn signal bulb be sort of legal or illegal.
It should remain legal as long as the bulb is amber when lit. You may want to check the vehicle code in your state though. IIRC, here in IL you can have a white signal, but I believe you need to have an amber reflector on the front somewhere.
http://search.dmv.org/dmv/new-york/vehicle code
Poke around there for a bit, see what you can find.
You should be able to clear them and put an amber bulb in. That's what I currently have. As long as the turn signal is amber when lit it should be legal.
