CEL Question
poniesviii
Houston/Waterloo
I'm thinking IAC.
My CE light keeps coming back. Car is finally starting to die sometimes at take off after already running for awhile. It always starts right back up, I put it in gear and gas it and it comes out of it, but sometimes bogs as I get the R's up, once they're up it's fine. Plenty of power, no misfiring.
Only below 1,200 rpm. Never above so far. 1,200 is a high guess, don't know for sure.
Constant check engine light this last week.. it's bogged prob 5 times; died three of those.
New plug wires didn't help.
IAC?
Thanks!
IAC most likely, followed by coil packs unless you did those two with wire. Might want to also check for a vacuum leak. A bad IAC sis *like* a vacuum leak so the symptoms are often the same. I guess I would spray, carefully, some starting fluid around and se what happens. If nothing, move onto the IAC.
