catless H-pipe
You can buy the double x pipes from Lincolnmotorsport which remove the 3rd cat. The front two cats stay in place, one is attached to the exhaust manifolds.
A decent pipe shop will replace the rear cat with a X. To get rid of the fronts you could run the FRPP Cobra shorties and then go custom from there or then maybe??? the Xs and Hs from the Cobra will fit. Would need to connect then to the VIII exhaust still but that would be easy. No one makes direct fit stuff for the VIII. But some Cobra stuff will fit but sometimes just better off with going custom bent with exhaust.
