Car Keeps Overheating Help PLs
Ls01LincNj
In NJ
i have a v6 ls about 160k miles first it was leaking antifreeze which im guessing was making it overheat i ordered hose that was broken causing leak fixed that then leak in the reservoir which i pour the coolant into it was cracked replaced that no leaks still overheats had a guy look at it said maybe thermostat took that out still overheats.Anything i could possibly check that could be causing it thanks for any help given.
Is your LS a 2001? If so, it has a hydraulic cooling fan. Sometimes those have problems. Also, did you correctly bleed the cooling system after it was worked on?
There's lots of information on cooling system/over heating problems in this forum. Please search and read.
yes a 2001 i didn't work on it myself a mechanic did i did notice him constantly bleeding it not sure if he did everything correct.But thanks i have been searching on here to see if i could find a problem similar
