Car chiming like crazy
Dsweat
Hillside
After my car started to chime away at me making it annoying to drive my LS. I did some research and located the yellow connector under my seat and it was broken like many other LS vehicles I read up on. So I plan to fix it. But my question is being that I'm working with a component connected with the airbags should I disconnect the battery first or will that cause a problem while I'm repairing the yellow connector?
I would.. Unhook the battery and wait 30 minutes.. Tap the connections together to dissipated any residual voltage and off you go.. Some have did it 'hot' per say, but I personally wouldn't
