Can't Get Stereo in w/ PIE Adapter
KevinACrider
Duncannon, PA
I got my PIE adapter in the mail today, hooked it up, all is well. I just can't get my stereo back into the slot with this big adapter back there. How did everyone else do this?
I was able to get both a video bypas unit and the steering wheel interface adaptor as well as all the necessary wires (3 pairs RCA and wiring harness) to fit in that hole. Believe me it was a PITA!! I ended up working the adaptors back into a little hole to the top right... this should place them just behind the glove box. FYI this is the same little hole I ran my I-pod full speed cable and aux video input through to get them into my glove box.
I hope this helps... it was the only solution I could see back there.
Your right, it is a bitch. I had to spend a long time moving everything around before it fit, but have faith, it will eventually go back in. I think i put the pie adapter in first then the factory harness.
I finally got it. I took out the glovebox and was able to see back there and move things as they needed moved. The quality of this versus my wireless FM transmitter is freaking ridiculous.
