brakes, anti-sway bars and wheels
RedCellSix
Elmira, NY.
Well finally took the plunge today...ordered the Premium brakes and Ceramic pads made by R1 Concepts w/ our great discount...thanks again Rich..... and ordered the 1 1/4" Addco front and rear anti-sway bars with the oil filter repositioning kit from Summit Racing. Finally, ordered 17" Borbet wheels from TireRack. Let you know after all is installed......KK will need your picture help finally. Gary
I see a couple of you have made the dive with front sway bars.
How hard is the install?
You'll like what the bars & brakes will do. Out of curiosity, what type of coils are on your car?
I have a set of SuperCoupe coils with a set of Tokico Blues and Addco bar in the rear. A set of subframe connectors and a front sway bar should round out my setup nicely, I'm not far from making the plunge on connectors but I am concerned about what the front bar install will be like.
Take a look at your oil pan and see how it looks. It would be a perfect time to get one if it's rusting through/damp...
Front sway bar isn't too bad, but I'm biased because I took the oem one out and put new in, it didn't fit, put oem back in, and took it out again and finally a new one in... for the rear I went through the same but it took two new bars to get the right fit. We could never figure out why I had so much trouble, but Addco was outstanding in helping me and swapping bars. I've dropped the sub frame even more times due to the leaking brand new oil pan I got too... :eyeroll:
I'll let ya'll know how the oil change goes in the spring with the bigger front bar and NO oil relocation kit ;)
:Bang
