Brakes and ABS
CookseysLs
Chicago
i was just wondering i had a bad rear brake caliper and i had to replace it would that have anything to do with my check advancetrac abs light being on and if it does now that its replaced can i reset it
Did your caliper freeze on and make your rotor get extremely hot? My ex did that to mine one day, which actually overheated and ruined the wheel speed sensor on that corner. Changing the sensor cleared the problem. As far as I know, running the car 10-20 mph is enough to clear ABS transient errors, there is no reset function.
check the wiring around that wheel. may have been damaged in the repair
