brake pedal on the floor!!!!
richduty455
South Jersey
So I'm trying to get the beater mark VIII on the road, but the brake pedal is SUPER low, like on the floor. I bled the system (in the order the manual says) but just the normal way (opened up the bleeders and had someone push the pedal) nothing, So then I thought it was a bad master. I got one and put it in, rebled the whole system and pedal is still low. Is there something else thats bad or is it cause I'm missing on doing something????
You must still have air in the system, The ABS system and all consumes alot of fluid. I would keep bleeding from the pass side rear until you stop seeing bubbles, then go to the drivers side front and do the same. The go back to drivers side rear and do same again. I use Super Blue brake fluid as it is colored so that you can tell you actually have the fluid purged thru the system.
