Blower motor wire
93mkviii
jacksonville
I've had an issue with my blower cutting in and out and recently it just stopped working all together. This article explains how to fix it: http://www.lincolnsonline.com/tech/00067.html so i went and moved the wire and heard the blower turn on and i knew it was a loose connection. I went to fix it and both ends of the orange wire that lead into the blower from the relay?(I don't know what it is connected to but it is a movable box), anyway both ends of the wire are extremely burnt and the white connector is partially melted. I had an issue with the compressor that blew on me and a cycling switch that was bad but i don't know if that is related. Anyone know if it will be fine just to replace the wire with a spare? Thanks.
