Balljoint size
RGL
Appleton
14mm 16mm wtf I went and ordered parts nd no one asked if i had 16 or 14! have to replace both Balljoints and left control arm got the control arm and the joint is still in it but is a 14mm, the one in my car is a 16mm! will it still fit, or can I inter change 14mm for 16mm?
there's no way the wrong one will fit. you will have to send it back. the earlier LS' had the 14mm i believe the cut off date max at 5 star ford knows. but LS' made in 01 for sure have the 16mm ones. happened to me as well, sux
control arm
what I ment to ask is can the conrol arms be changed so the 14mm balljoints can be used?
i believe you have to upgrade other suspension parts. much more money and time. just get the other ones
