bad sputter
qtuic
Charleston
Morning guys hoping some can help out got a 04 lincoln ls 3.0 have a really bad sputter when set over night first crank n morning it idles high then die down some time cuts off I've tried replacing all spark plugs. all coils. Pcv. Both upstream oxygen sensor still nothing has changed any help would we greatly appreciated
Wouldn't a maf kick the cel on also one time when i was driving with a half tank of gas it dropped to E and cut off but only did it once
Might consider the IAC (Idle Air Control) Valve too. If it is failing, it can cause idle inconsistencies and will likely not set a code. On #3 on my LS.
