Awake doing research, bahaha I <3 my LS.
Hector
St. Louis
Hey all it's been a while since I've had the pleasure of being here well it's 4AM.
Just sharing since it's caring. I've had a "stumble" for about a week now and I did all the regular diagnostics, my obd2 said "cylinder 4 misfire" so I replaced it (since I have so many laying around now) which didn't solve it then I disconnected one by one trying to see if the "stumble" remained or got worse, well turns out none of them were bad and the fuel injector plugin was not fully inserted :D should've been my 1st guess, but oh well.
I've had this damn P0420 code for a while guess I'll try my luck with the 2 sensors before the cat if not time for some new kitty cats. :rolleyes:
I'm doing sway bar link kits fronts and rears, front ball joints (already attached) and figure out why my ABS, Brake and TC lights are on its like damn Las Vegas in my car at night lol.
On the funny note my sister has an 04 LS8 and her A/C quit working on a 104 day here in StL. No check engine light so I figured perhaps its low on freon went checked and it was packed to the core so moved onto the clutch perhaps it was toast so I hot wired it from the fuse/relay panel under the hood and it worked and blew cold air turns out that Cyl #3 was misfiring causing the a/c not to engage the clutch and leave her with no A/C. Interesting never knew it could do that but then again our cars are Very Special :(
Oh well I'm done with talking to myself, :cool:
On my 2002, When temperature drops below 10 Degrees (Celsius) My ABS light comes on. So I had it diagnosed by the Dealer, And they said it was my ABS Module, and the part is $890, and labour is $250 + Taxes so it was close to $1500.
So I paid them their $100 Diagnose fee, and got the hell outta there. Haven't replaced the module cuz it only does this in the cold...
But anyways sorry to hear about your slew of issue.. What years your LS and engine size?
Zero, from one owner to another, maintenance that car properly and stop worrying about stereo items. LOL.
yea I figured it would be some type of issue, it comes on and off mostly all are on, but for $1500 they can stay on and light up my future :shifty:
2000 LS8
