since you just got a new Viper system, this is a waste of parts and time for you.
just program the viper system to unlock all the door when you turn the key off!
its a simple setting.
Clifford called it a short stop feature back in the day, and its also been referred to as a turbo timer. But really when I want to get out of the car real quick, and leave the car running, I hit the button and it instantly unlocks all the doors and turns on the dome light in the car. I don't like that, so I had them disable the feature. Turns out the car is responsible for the dome light, because it thinks you're unlocking the car from the key hole. I don't want the doors to unlock on short stop either, only when I turn the car off.
Though I still can't use this circuit, because if I remote start the car and then shut it off without ever going to the car, it instantly unlocks the doors.
it should be noted that if you use too big of a capacitor, it will start to open all of the windows and sunroof every time you turn the key off if it holds the second relay on to long.
also as the power in the capacitor fades, it could trigger the relay on and off a hundred times and cause a lot of extra wear on the lock actuator from trying to unlock several times each time.
I actually meant connecting to the actual unlock button inside the car. They have no control over the windows. Also, the capacitor would only cause the second relay to fire once. Once the voltage has dropped below the threshold to trigger the relay, it won't switch the circuit anymore.
We did something similar on a friend's car, but we used the wiring from the shifter to unlock the car when put in park. The original idea came from LLSOC (I think that's right), but I have no clue why they decided to use the shifter to trigger the event.
My '11 F350 has auto unlock. You can disable it in the vehicle settings, but I Like to leave the feature on.
Seriously? I've owned and driven at least 6 or 7 Ford made vehicles over the years (including an 08 F250), and I have yet to see this feature from factory. Not even my Navigator has it.
