Areas to Por 15 a Mark?
Lownslowlsc
N il
I know the rockers and lower doors are usually the first to rot. What areas would you guys suggest doing it to as a preventative measure? Accessability is key.
Can it be used inside? Like "smeared" by the lower rocker via the rear speaker holes. Any particular areas under the car that would lead to rocker rot(dont be a smartass) that can be treated?
Even at a pint its around 30 bucks so i'm still kinda iffy if i want to mess with it..
All the places Marks rot is from the inside out... no amount of smeared on crap will fix that. The only real solution is buying a rust free example and not driving it in the winter.
