Anyone replace an a/c compressor on an VIII?
Icarus
Ontario, Canada
Anyone have any tips etc to replacing the a/c compressor in a '94 VIII?
Will I need to drain/remove the rad like the manual says?
no rad drain,
after system is evacuated you remove the connections to the compresor and i think its only 3 bolts(10mm if i remember correctly)and it falls off,of course remove serp belt too,i dont think there is anything to it,but someone else can chime in here.
I found out you can't take the compressor out from the bottom without doing it the way the manual says (pulling the rad) or dropping the sub frame... :rolleyes:
You can how ever take it out from the top quite easily once the air box/filter is out of the way! Much better access to two of the bolts as well ;)
Thanks to NYC LSC and everyone for helping :) At least it turned out not to bad a job to do...
ps: If you buy a compressor and it says it has oil in it... double check! There was none in mine even though the box and instructions said it did!
