Any other size...
Lucky_Ls
Round Rock
Hey you guys,
I know that the 5 x 108 bolt pattern is the size that works for the LS's but is there something else that works? I think I've read on here (can't find it on search function) that 5 x 4.5 will work as well? I'm I just seeing things or is that true?
5x108=5x4.25 not 5x4.5
Its not that its a different size. 108mm is 4.25"s.
Ok so I was off by a fraction. But you're telling me that if I can find a set if rims that's 5 x 4.25 they'll fit?!
+38 will fit near perfect, i would go with 42 or 45 though. I have 18" +38 and i needed a 2mm spacer in the front due to the wheel style. But they fit and look good, if you are/plan to drop i would go higher offset.
Fonsito is pretty low. He has 18x8 with a +38 and 245/40 tires and claims its perfect. I have 19x8.5 +38 235/35 and say I need bigger tires.
Yes again 108mm is 4.25 inches! Some people rather just use inches instead of millimeters.
What sidewall? I really want more sidewall.
For some reason I feel I should have picked up on that:slam
and why is that...................:shifty:
2002 LSE
18" ADR propulsion, toyo proxes 245/40
Blue tooth-through speakers
Angel Eyes...homemade
-We got to land this plane, this lady needs a hospital.
-What is it?
-Its a big building with patients, but thats not important right now"
