TJKashin
I have run into the issue of a strong antifreeze odor under the hood after running for awhile. I'll try and explain everything to the best of my ability here, maybe someone can tell me what could be wrong.
First of all, When I drive on the highway, it seems that the temp gauge hardly goes up. There is heat, but the gauge only registers a little less than a quarter of the way up. Then, when I am around town or cruising under 40, it will register up to halfway. After driving for awhile, the odor of antifreeze can be smelled under the hood. I have not lost any coolant, do not see any fresh drips or leaks in my garage (I even parked over some clean white paper for a couple days). I have heat 90% of the time, but occasionally there seems to be a cold spot that shows up.
I suspect a couple of things, but maybe other members might have other suggestions.
1) Thermostat either stuck open or non-existent. I haven't done anything as far as checking that yet due to the ass-biting cold weather here in Chicago.
2) Heater core hoses about to go out, no actual leak but just about to.
These are the things I have come across in past experience that might lead to this, but since I am a new Mark VIII owner, there might be something else I am not aware of, and yes, I have searched here and a couple other sites before deciding to post a question.
Thanks for any help in advance...
Tim K.
98 LSC Black/Black
Tim K.
98 LSC Black/Black
