Glass Panel, Height
The correct position of the glass to the roof is as follows:
Front Corners: Flush to 1mm below roof.
Rear Corners: Flush to 1mm above roof.
1.Cycle glass from full open to full closed position.
2.Remove three halo retaining screws along front of opening inside of vehicle and slide halo and sunshade fully rearward to expose six glass retaining screws (three each side).
3.Loosen six glass-retaining screws. Then, tighten them so that they are snug, but not tightened to specification.
4.To adjust only the front of glass, loosen the center and front screws. If it is desired to adjust only the back of the glass, only loosen the center and rear screws.
5.To check height setting, open the glass about four inches, then return to the closed position.
6.Tighten the glass retaining screws.
7.Slide halo forward and replace three retaining screws.
8.Close sunshade if desired.
Glass Panel, Fore-and-Aft
1.Operate sliding glass panel to the full-open position.
2.Loosen 12 screws (including the single screw at each front rail corner) retaining the adjustable side rail covers.
3.Locate and use the series of hash marks at each front rail corner. Adjust glass panel fore or aft as required, making sure both sides are uniform to hash marks.
4.Tighten all retaining screws.
CAUTION:
Hand tighten all screws. DO NOT use air tools or damage to holes in housing may occur.
No pretty pictures
